Kubota M4800SU won't start - checked starter, checked battery
   / Kubota M4800SU won't start - checked starter, checked battery #1
thsteger
Cookeville, TN
Kubota M4800SU
Hi. I worked with my tractor about 15 mins last week (fired right up, as always), stopped it, turned it off and did some other things. Jumped back on a couple hours later and it wouldn't start. It doesn't turn over far enough to fire. It turns just enough to see the fan move, then stops. Seems like the starter doesn't have enough power to keep it turning.
I had some starter problems last year that I had fixed, so I took it to a different starter repair guy who said that the clutch pack was worn out and fixed it for a little over $100. He said all the electrical components were fine. Put it back on and the same thing happened, so I took the battery off and had it checked. It's good. What should I check next?
Thanks,
Thom
   / Kubota M4800SU won't start - checked starter, checked battery #2
Have you cleaned & tightened all 4 battery cable connections??
   / Kubota M4800SU won't start - checked starter, checked battery #3
X2. This is the next step. I actually make it my first step. You can lose a lot of current through resistance at poor connections.
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
