KUBOTA M120DTC Hydraulic Question
   / KUBOTA M120DTC Hydraulic Question #1
GrayMule
Tri-Cities TN
1951 Ferguson TO30
Hey guys hope all is good.:)
I was hoping somebody might be able to answer a simple question about the Kubota M120DTC hydraulic system...is it an open or closed system?
Most curious about the Steering Control Valve. Thanks in advance.
   / KUBOTA M120DTC Hydraulic Question #2
All Kubota's I know of that size are provided with a separate steering pump that is an open centre fixed displacement pump. The steering is via an orbital valve which is usually called hydrostatic power steering.
Since it is a fixed displacement pump, couldn't I run that valve off my FEL pump [with a priority valve, of course]?
   / KUBOTA M120DTC Hydraulic Question #4
Yes I suppose, this is how older single pump tractors like the Case IH 85 series etc where plumbed. The lines might be way too small though as the main pump is 3-5 times the size o the steering pump. It also sucks. You'd lose the 3 point hitch while steering, under load. The loader would stop under steering load etc.
Are you trying to avoid fixing the pump? You could put a belt driven automotive power steering pump like many Ford/NH's had in the old days. Separate reservoir but not as much flow, can't steer as fast.
   / KUBOTA M120DTC Hydraulic Question #5
One other thing, not sure about the Kubota, but on my large MF, the steering pump also runs a bunch of the transmission functions and the wet clutch.
Actually, I was thinking of using the Kubota valve on another tractor for a power steering conversion. I was thinking of plumbing it off the fel pump on a priority valve, as I mentioned.
Its still just an idea at this point, but if I knew for sure it would work with what I have to work with - l would most likely do it.
The pump I have is a Cessna, I don't remember the exact flow, but it seems like it was around 11-16 gpm..planning on checking it again. I have two 17 inch cylinders with around a 1.5 bore, 2.5 dia and 10 inch stroke.
The Kubota valve I was thinking about purchasing on a fairly good deal, which led to my post. I cant find any info on the valve.[Shoot, cant hardly find anything on the M120DTC tractor, itself].
Again, I am still up in the air about it because of the little info on the valve. It looks something like a CharrLynn/ Eaton 10 series valve, but really unsure.
the plan would be for the pump to only power the FEL and steering
   / KUBOTA M120DTC Hydraulic Question #8
I'm sure you could get a conventional orbital valve for cheap, it would have a more common fitting on it too. The Kubota is likely iso or din metric fittings that are about 20$ each to do anything with. Without knowing the cc's, its hard to know the cylinder size you need.
yeh, I really didnt think about the metric fittings...I know of a Sauer Danfoss unit, I could get for around the same as the one off the Kubota. I will probablly go that route. Thanks Zuki, I appreciate your post. That Danfoss unit is a ospb 100..I welcome any input.
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
