Kubota M 4700 starter problems
/ Kubota M 4700 starter problems #1
gmccall
Forney Texas
kubota
Problem started with trying to start the tractor recently.
First I found the battery was bad so I bought a new battery. Then I discovered rats had chewed up the headlight wiring and who knows what else.
But first things first I was determined to start the tractor. With the new battery installed, I still got a no start from the starter switch.
I then installed a jumper trigger switch wire from the battery cable wire on the solenoid to the starter connector on the solenoid. ( I disconnected the positive wire that feeds the tractor electrical from the solenoid to the starter switch. Got a click, and then all went dead. No dash lights, nothing.
Checked all connections including wiring behind dash and found nothing. I then thought the starter relay was bad, but did not get around to testing relay. After a while with original battery cables reconnected, the dash lights would come back on when turning the key to on. As soon as I hit start on the starter switch, I would hear a click and a repeat of the click and systems of nothing would return.
To cut to the chase, the problem ended up being bad battery cables. I replaced both and all worked as it was supposed to.
The cables were not allowing enough amps get to the tractor components.
I did have to rewire the headlights.
/ Kubota M 4700 starter problems #2
Good news.
However, "Search" the forum. This scenario is described numerous times. May have saved you some effort.
Deal to the rats next. asap.
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower  (A62679)
Wolverine...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
72in. Land Plane (A65640)
72in. Land Plane...
60in. Work Bench (A65640)
60in. Work Bench...
