Kubota LX2620 towing capacity
   / Kubota LX2620 towing capacity #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I'm going to replace my old B7800 with LX2620. LX is going to fill all my needs. The question is towing capacity.
Sometimes I need to move empty dump trailer (3300Lbs) a few hundred feet.
B7800 did it with no problem. Can LX2620 do it? If not I would have to go with L2502... Thanks
   / Kubota LX2620 towing capacity #3
Absolutely, you shouldn't have any issues moving the trailer around. Just be patient, use your noggin, and you'll be fine.
   / Kubota LX2620 towing capacity #4
One thing a lot of people don't realize is the D1703 engine in the 2502 is quite a bit larger and more torque than the D1305 in the 2620.
Thanks, I realize that. But if LX can do it it's all I need
   / Kubota LX2620 towing capacity #7
I have moved a 7.000 lb travel trailer with an 18 HP Bolens riding mower. Not far or fast or on soft ground.
   / Kubota LX2620 towing capacity #8
Sometimes I need to move empty dump trailer (3300Lbs) a few hundred feet. Can LX2620 do it?
The owners manual on page 32 lists the max trailer weight for the LX2620 as 3300 lbs. This would be for normal use so it should not be a problem moving it just a few hundred feet.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
402 (A52706)
402 (A52706)
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
Terms & Conditions of Auction (CHECKOUT DATES) (A59213)
Terms & Conditions...
