Kubota LX2620 towing capacity
   / Kubota LX2620 towing capacity #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I'm going to replace my old B7800 with LX2620. LX is going to fill all my needs. The question is towing capacity.
Sometimes I need to move empty dump trailer (3300Lbs) a few hundred feet.
B7800 did it with no problem. Can LX2620 do it? If not I would have to go with L2502... Thanks
   / Kubota LX2620 towing capacity #3
Absolutely, you shouldn't have any issues moving the trailer around. Just be patient, use your noggin, and you'll be fine.
   / Kubota LX2620 towing capacity #4
One thing a lot of people don't realize is the D1703 engine in the 2502 is quite a bit larger and more torque than the D1305 in the 2620.
Thanks, I realize that. But if LX can do it it's all I need
   / Kubota LX2620 towing capacity #7
I have moved a 7.000 lb travel trailer with an 18 HP Bolens riding mower. Not far or fast or on soft ground.
   / Kubota LX2620 towing capacity #8
Sometimes I need to move empty dump trailer (3300Lbs) a few hundred feet. Can LX2620 do it?
The owners manual on page 32 lists the max trailer weight for the LX2620 as 3300 lbs. This would be for normal use so it should not be a problem moving it just a few hundred feet.
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
Manac Walking Floor Trailer (A50322)
Manac Walking...
