Kubota loader valve ( Regenerative)
   / Kubota loader valve ( Regenerative) #1
rckconaway
I have the two position dump valve . Im trying to use it to rotate chute on snowblower. The only way I can move the chute to the right is to use the second position on dump. Is this doing damage? And if so can this valve be modified. This is a 4 position with power beyond mounted on a B-2910.Thanks
   / Kubota loader valve ( Regenerative) #2
Welcome to TBN:D
I am not sure about the "two position " valve you have, but the Regen function of a valve can make a a single cylinder (not single acting) not function properly, especially when there is no weight to help get the cylinder moving like there would be on a bucket. It doesn't sound like any damage will be done as long as the system is not going into relief.
For a good read on regenerative valves, read THIS.
Thanks for the come back. The added info explained everything
Kenworth T800 Day Cab Truck Tractor (A49461)
Kenworth T800 Day...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
