Kubota loader valve ( Regenerative)
   / Kubota loader valve ( Regenerative) #1
rckconaway
I have the two position dump valve . Im trying to use it to rotate chute on snowblower. The only way I can move the chute to the right is to use the second position on dump. Is this doing damage? And if so can this valve be modified. This is a 4 position with power beyond mounted on a B-2910.Thanks
   / Kubota loader valve ( Regenerative) #2
Welcome to TBN:D
I am not sure about the "two position " valve you have, but the Regen function of a valve can make a a single cylinder (not single acting) not function properly, especially when there is no weight to help get the cylinder moving like there would be on a bucket. It doesn't sound like any damage will be done as long as the system is not going into relief.
For a good read on regenerative valves, read THIS.
Thanks for the come back. The added info explained everything
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
JCB 5 10 56 (A50490)
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
Danuser Digger F-8 (A51039)
Danuser Digger F-8...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
