Kubota loader becomes anemic when hot
   / Kubota loader becomes anemic when hot #1
wsc9tt
Northeast Indiana
Kubota MX5100HST
So I have a 2015 Kubota MX5100HST that has about 100 hours of light use. Lately, I have been doing some digging and I find the front hydraulics lose power and moves very slowly after it has been working hard for 30 minutes. I assume that is when the fluids are all hot. First I checked the radiator and did find that it was rather gunked up with grass, but after cleaning that all out the symptoms still exist and when the problem occurs I find that I can put my hands on both the radiator and the HST radiator so I don't think anything is that hot. The guage also seems fine.
Before I take it to the dealer I thought I would try to fix any obvious problems to save myself some money. At the 50 hour service, I changed the HST filter but the Hydraulic oil filter isn't scheduled to be changed until the 400-hour service. I thought about doing that now, but I don't want to buy 11 gallons of new UDT oil.
Suggestions on what could be causing this problem and what I should try?
   / Kubota loader becomes anemic when hot #2
Could be you are sucking air after it gets warm. Check the suction line to the hyd pump. There is a small rubber hose that hooks the steel line together, check for cracks and lose clamps.
Those lines all seem new and I don't see any issues. I should probably take it to the dealer.
   / Kubota loader becomes anemic when hot #4
...I changed the HST filter but the Hydraulic oil filter isn't scheduled to be changed until the 400-hour service....
Not 100% sure of your model but the hydraulic oil usually isn't changed until 400 hours but BOTH hydraulic filters should have been changed out.
PS. The return hose can "look" new when they are cracked. Squeeze them and if they are cracked, it will show up, usually on the outside bend. BUT that problem was fixed a while ago and mainly it was for the economy L's.
   / Kubota loader becomes anemic when hot #5
There is no way those hoses should be bad on a 2015 Kubota with only 100 +/- hours. My 19 year old Kubota still has all it's original hoses, and have been problem free. Unless Kubota has cheapened their product line...........
wsc9tt, I would call the dealer first and see if they could recommend a solution to your problem, before taking the time and expense of hauling your tractor to the dealership.
   / Kubota loader becomes anemic when hot #6
Does the curl function and the 3 point hitch work when warm? If yes then the problem is in the lift circuit of your FEL.
Typically slower speeds / loss of pressure when warm is do to the oil by-passing or leaking some where.
The dealer suggesting trying to change the main hyd oil filter first. Just swap it quickly and I shouldn't lose too much oil.
   / Kubota loader becomes anemic when hot #8
use the shop vac trick!!! stick sv hose in the inlet
   / Kubota loader becomes anemic when hot #9
Ditto on what teg said. Used that several times. Couldn't believe it the first time. One of the coolest tricks ever and didn't waste more than a cup of hydraulic oil
   / Kubota loader becomes anemic when hot #10
I never saw an answer to the question about the curl or 3 point.
I will be surprised if changing the filter makes a difference since warm oil flows easier than cold so it would pass through the filter much easier when warm.
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
1049 (A50459)
1049 (A50459)
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2014 CATERPILLAR 740B OFFROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
