Kubota lifts Engine--for real
   / Kubota lifts Engine--for real #1
TresCrows
Elite Member
Kansas
Kubota BX2200, Kubota B2410
Here is a picture of the Kubota 2410 lifting a 25,000 dollar egg. /w3tcompact/icons/shocked.gif
Sorry about the "deleted" subject post, we messed up with the attachement. J
Here is another picture of the bright yellow custom built 200 horsepower aircraft engine. J
The Kubota saves the day again. No one ever around to help lift except for the 'bota. A loyal friend. Engine is safe in the garage, thanks to the Kubota. Side view of the most expensive and fragile thing I will likely ever lift with the Kubota. J
   / Kubota lifts Engine--for real #4
Looks similar to the engine I pulled out of my '74 VW Thing.
Aircooled horizontally opposed 4 cylinder? I trust it is more reliable than my Thing's engine.....?
Mark
Oh yeah, I hope so. This one is 360 cubic inches and makes 205 horsepower at 2700 RPM. It is built from "certified" parts. It is essentially a hot rodded Lycoming IO-360. It has high performance fuel injection, it has been balanced, blue printed, the cylinders flowed and ported on the bench and has been modified for continuous inverted flight. About the only thing it has in common with your "Thing" engine is that it burns gasoline.
I kinda wish I had a Thing. Those were fun, I built a few VW engines up once, one for a Ghia convertable and another for a Blue Hippie Bus, it would pop wheelies and was fun on the beach. Those are approx 100 cubes, well, the Ghia was 1860 and the bus was a 2180 with dual carbs. J
   / Kubota lifts Engine--for real #6
JR,
Likely the only time the "load" will be worth more than the "loader". /w3tcompact/icons/crazy.gif
I know nothing about aircraft engines, but that sure looks like a beaut!! What's it going into??
Kevin
Kevin, it is going into an RV7A. Hey, guess what, I had it built by a shop in Canada. It got hung up on the border but it finally made it. Yippee. J
   / Kubota lifts Engine--for real #8
Ok, so, quit teasing its going in a.......
Anyway, beautiful engine! and the botas got a good look to. Kinda partial to the orange and yellow myself, wifes bike yellow(after she high sided it) my bike yellow (Duc)
and the silly english sports car yellow/polished aluminium.
Still havta finish the flying lessons 53hrs 3airport/instuctors guess I should just go somewhere to finish.
Do you have a pic of what shes going in? If you have to, put the bota in the background. Will I have to look for it in july at Osh?
Cheers
Tony
   / Kubota lifts Engine--for real #9
Hey, now I know how to lift that old flathead 6 out of my pickup!
Pete
   / Kubota lifts Engine--for real #10
<font color=blue>now I know how to lift that old flathead 6 out of my pickup</font color=blue>
Pete, that oughta be easy with your tractor. I lifted an entire 454 Chev. engine with the automatic transmission attached over the grill and into an '84 Suburban with my B2710. But that was about the maxiumum weight and height I could get with my tractor./w3tcompact/icons/laugh.gif
I don't think I'd have tried it if that engine had been as valuable as Trescrows airplane engine./w3tcompact/icons/laugh.gif
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
Dixie Chopper LT2000 Zero Turn Mower (A53117)
Dixie Chopper...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
72'' root grapple (A53421)
72'' root grapple...
