Kubota LA680 power beyond ?'s
   / Kubota LA680 power beyond ?'s #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have a kubota L4200 with LA680 loader, I am told it has Power beyond? I need to know how to tap into this because I am building a grapple bucket and need the extra hydraulics ????
   / Kubota LA680 power beyond ?'s #2
If there are seven lines connected your FEL valve, then you have PowerBeyond ready to go...If there are only six then you will have to determine if PB can be added to the valve by adding a special plug to it.
The ports on the valves are usually marked with letters, report back with how many hoses and the letters (not on the ports going to the cylinders) and we can help more:D
   / Kubota LA680 power beyond ?'s #3
Look at the loader valve and there is "PB" marking on the hose coing to the top cover. You want to tap into this circuit in series with your grapple valve.
Remove this hose at the loader valve and install your open center grapple valve and reconnect the discharge from the grapple valve to the top cover hose.
Good luck
Super Material Lift MH1000 (A53472)
Super Material...
2015 JCB 550-170 Telehandler (A51573)
2015 JCB 550-170...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
