Kubota LA680 power beyond ?'s
   / Kubota LA680 power beyond ?'s #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
I have a kubota L4200 with LA680 loader, I am told it has Power beyond? I need to know how to tap into this because I am building a grapple bucket and need the extra hydraulics ????
   / Kubota LA680 power beyond ?'s #2
If there are seven lines connected your FEL valve, then you have PowerBeyond ready to go...If there are only six then you will have to determine if PB can be added to the valve by adding a special plug to it.
The ports on the valves are usually marked with letters, report back with how many hoses and the letters (not on the ports going to the cylinders) and we can help more:D
   / Kubota LA680 power beyond ?'s #3
Look at the loader valve and there is "PB" marking on the hose coing to the top cover. You want to tap into this circuit in series with your grapple valve.
Remove this hose at the loader valve and install your open center grapple valve and reconnect the discharge from the grapple valve to the top cover hose.
Good luck
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
