Loader Kubota LA351 SN#12210 Quick Connect Leaking
   / Kubota LA351 SN#12210 Quick Connect Leaking #1
theide
Little Rock, AR
Kubota B2400
I recently had a leak in the quick connect hoses for my LA351 Loader so I replaced all 4 (They were the original hoses so I figured I would take the downtime once rather than have hose after hose fail). Before the leak in the hose, the quick connections to the control valve were clean and never disconnected. After replacing the hoses, there are a couple that leak. The tractor is a B2400HST4x4. I suspect the o-rings in the quick connect couplers are shot and when taking off and putting back on was all they could take. I would like to change out the o-rings first before forking over $ for a new female coupler. What is the appropriate part number for these o-rings or how can I find out what the appropriate o-ring would be.
   / Kubota LA351 SN#12210 Quick Connect Leaking #2
you can take a scribe or small screw driver and roll the o-ring out, take it with you to a tractor supply or hardware store.... they will have the O-ring you need.... KennyV
Butterfly Artwork (A55758)
Butterfly Artwork...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2008 International Bucket Truck (A55973)
2008 International...
