Loader Kubota LA211 FED loader dump/ rollback quit while plowing snow
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #1
SquirrelRidgeFarm
Webster, WI
Kubota BX2200
Hi, all..... I was happily plowing the first snow of the season and 15 minutes in, the dump/rollback function quit. The bucket is sort of midrange between the dump/ rollback extremes. The arms go up and down normally. When I try to dump/rollback, the hydraulic lines jump a little(like normal) so I think there is pressure to the cylinder. If I put the arms all the down and try the dump/rollback, it will work to the point that it will lift the front wheels off the ground. So.... when arms are down, the cylinder works. I checked the hydraulic dipstick and I have fluid.
Any ideas? Any suggestions as to what to try first? Many thanx...... We are currently mid-blizzard and I plowed my 1/4 mile driveway with a walk behind snowblower, but I don't want to do that too many times!
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #2
YA, plug your hoses in properly.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #3
Ice in the control valve or defective control valve if the hoses are properly plugged in. Can you float the FEL?
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #4
If not a simple QA that popped off, I'd bet on something loose or broken in the control lever to control valve linkage. Bunch of little pins and clips in there.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #5
Make sure your 3PH lift lever is in the neutral position.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #6
What roms are you running at? If u are running at low rpms try ramping it up a bit.
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2021 SKYJACK SJ3219 ELECTRIC SCISSOR LIFT (A51242)
2021 SKYJACK...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
