Loader Kubota LA211 FED loader dump/ rollback quit while plowing snow
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #1
SquirrelRidgeFarm
Webster, WI
Kubota BX2200
Hi, all..... I was happily plowing the first snow of the season and 15 minutes in, the dump/rollback function quit. The bucket is sort of midrange between the dump/ rollback extremes. The arms go up and down normally. When I try to dump/rollback, the hydraulic lines jump a little(like normal) so I think there is pressure to the cylinder. If I put the arms all the down and try the dump/rollback, it will work to the point that it will lift the front wheels off the ground. So.... when arms are down, the cylinder works. I checked the hydraulic dipstick and I have fluid.
Any ideas? Any suggestions as to what to try first? Many thanx...... We are currently mid-blizzard and I plowed my 1/4 mile driveway with a walk behind snowblower, but I don't want to do that too many times!
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #2
YA, plug your hoses in properly.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #3
Ice in the control valve or defective control valve if the hoses are properly plugged in. Can you float the FEL?
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #4
If not a simple QA that popped off, I'd bet on something loose or broken in the control lever to control valve linkage. Bunch of little pins and clips in there.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #5
Make sure your 3PH lift lever is in the neutral position.
   / Kubota LA211 FED loader dump/ rollback quit while plowing snow #6
What roms are you running at? If u are running at low rpms try ramping it up a bit.
2011 Ford F-150 Ext. Cab Pickup Truck (A55852)
2011 Ford F-150...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
ATTENTION PLEASE READ (A56469)
ATTENTION PLEASE...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2013 Buick Enclave SUV (A55853)
2013 Buick Enclave...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
