Kubota LA211 control valve issue
/ Kubota LA211 control valve issue #1
NotchLickKat
KY
MF 50D
I am having an issue with my FEL in cold weather. The control stick can be actuated in the 6 and 9 o'clock positions, but not in the 12 and 3 o'clock positions. I can heat the control valve and it will work fine. If above freezing, it works fine. The rods (unsure of proper terminology) will come out of the valve body, but not go in when cold.
Anybody seen this before?
/ Kubota LA211 control valve issue #2
You may have moisture in the cans on the bottom of the valve an may freeze.
Remove the cans, clean ,lube and re-install with weep hole down.
2020 Chevrolet Tahoe (A60352)
2020 Chevrolet...
2008 FORD F-150 (A60736)
2008 FORD F-150...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
