Kubota L6060
   / Kubota L6060 #1
Krw232
Any thoughts on this machine used as a 100% snow removal piece of equipment? There's a 2019 L6060 with about 1200 hours and a Pronovost(?) drag blower.
This is for property management in Ontario, Canada.
I'm seeing horror stories of machines at this age with fuel system issues, is this a common defect or am I just seeing the worse?
Thanks everyone!
   / Kubota L6060 #2
The L60 series has a strong reputation, and no specific problems that I am aware of. My L4060 has about 1200 problem free hours.
Sounds like that machine has seen some hard commercial service, so I would look it over carefully.
   / Kubota L6060 #3
does the machine have a service log? hrs? if possible, i'd hire an impartial tractor mechanic to review the machine as suggested above. take a look at the cond of air filter for starters. good luck
   / Kubota L6060 #4
I own 2 L6060's. I really like them as they are a good fit for my needs. But, I am in South Louisiana and we get a little snow here about once every 10 years or so.
I did have a major fuel issue with my older machine a few years. You can read that story here. Water in fuel causes $10,000 damage to my Kubota Grand L6060
Even after that fuel issue, I bought another one. The newer one has had a couple of minor issues with fuel lines getting blocked, but nothing major.
   / Kubota L6060 #5
One would be foolish not to follow daily check items before a long day of service. One of them is to check the fuel water separator. The Kubota Grand L6060 are SOLID tractors.
   / Kubota L6060 #6
the newer models have better fuel filtration but I don't know when they started putting a better fuel filter. not sure if they added a second smaller micron filter or if they replaced the original filter with a better one.
   / Kubota L6060 #7
Check out this YouTube channel for Stefano Narducci, co-owner of Northern Snow. He has a fleet of around 40 of the L6060 with the Pronovost blowers in Canada doing residential snow blowing. He is a big fan of the L6060 and Pronovost blowers. He is phasing out the JD 4066R machines in favor of the L6060 because of maintenance issues, the JD machines just don't hold up. He also is phasing out his M5-111 for M6-111 Kubota.
Stefano Narducci
   / Kubota L6060 #8
As with ANY used tractor, due diligence is paramount. Have it inspected by a competent and unbiased dealer mechanic and additionally, pull an oil sample and have an analysis done by a lab that specializes in oil analysis like Blackstone Labs, for instance.
Lube oil and gearcase oil analysis will reveal things you need to know and things you don't need to know as well....
Blackstone provides FREE oil analysis kits btw. You pay when you send in the samples.
   / Kubota L6060 #9
I have an L5740 which is the predecessor to the L6060. It's now 18 years old with 1000 hrs, and I have not had a single problem with it. Not one. I HAVE fixed a few things, but they have all been things that I have broken.
   / Kubota L6060 #10
My l4060 is going strong at 1,100 odd hours. I've had front wheel bearing issues, once under warranty, once recently. I believe the l5?60 & L6060 have a beefier front axle.
I wish I had the extra 20hp for mowing & roading the machine. Traction wise it's iffy wether I'm limited by traction or power.
2019 Ford F-550 V-Mac DTM70 Air Compressor Flatbed Truck (A44571)
2019 Ford F-550...
2022 Ford F-150 Crew Cab Pickup Truck (A44572)
2022 Ford F-150...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A47484)
2025 Wolverine...
Case 1030 Case Rear Wheel Weights (A47484)
Case 1030 Case...
2025 Wolverine VR-11-66W Vibratory Roller Attachme (A47484)
2025 Wolverine...
APEX Ag Equipment Hyperdisc H18/20 | High-Performance Tillage Disc for Precision Farming (A46878)
APEX Ag Equipment...
