L5740 or some tractor
   / L5740 or some tractor
Snow is big business here. We'd need to get a truck with a plow for light days, then blow on heavy or to get the sides that are built up removed. We have seen 48" in 48 hours.
   / L5740 or some tractor #72
Why does he need the ati QA? The Kubota factory one on it should work just fine.
My mistake - I read it didn't have SSQA - but after looking at the other pictures it does, All he needs is the 3rd Function and the rear remotes. A lot simpler and less $.
   / L5740 or some tractor #74
This is my opinion Arly so take it for what it’s worth.
I wish I had a grapple but get by with my forks. You can try and get by with the forks and add a grapple later. They are pricey is why I bring it up, if you have it in your budget I’d get it now then.
Rear remotes? I don’t have any and have never wished for them. I completely understand there use but for example I put a rear blade on and set it up and use it as is. Look at how you would use rear implements and decide if you need them or not.
I’m not trying to cheap you out on your future rig I just don’t want you to add stuff you might or might not need. It’s easy for other people to spend your money.
   / L5740 or some tractor #75
If you've got the money to make it work, get the remotes and 3rd function. You'll never regret a dedicated grapple.
   / L5740 or some tractor #76
Fair statement, it's only money after all. If it's only money, then why not buy new instead?
   / L5740 or some tractor #77
Well to be fair, the prices between new and used Deere/Kubota equipment could add a lot of accessories. The MSRP of these machines is painful!
   / L5740 or some tractor #78
The primary reason why I purchased the Green weld on bucket grapple and the Vevor add on debris forks is adaptability with existing equipment. I already have enough 'stuff' and adding a dedictaed grapple would just add to the stuff inventory.
I can remove both the clamp on debris forks as well as the Green grapple from the bucket (I used the light duty material bucket I own as the base for the Green grapple). I can remove both the grapple attachment as well as the forks in a couple minutes if I require the bucket for other tasks and both my M9's are SSQA 2 pin attach to begin with and I already own a blower (72" lucknow rear mount blower as well as my 10 foot power angle snow plow that is SSQA in the first place, not that I like plowing snow, because I don't. Cost wise, the Green grapple as well as the add on forks were a ton less expensive than a dedicated grapple to begin with other than welding on the hrapple base which was a non issue for me. Remeber, I own and operate a welding and fabrication, short run machine shop so I have the tools necessary for that modification.
I'm all about multi use implements and easy interchangeablilty and the Green grapple as well as the Vevor clamp on debris forks meet that requirement for me. There we a ton of negative reviews on Amascon concerning the Vevor clamp on DEBRIS forks but it was easy for me to surmise that people were buying them and useing them to mover heavy things like boulders and bending them. Not designed or built for that. They are built for DEBRIS removal only. I aso own a set of SSQA heavy duty pallet and skid forks rated for 6,000 pound capacity and the Vevor debris forks aren't for that at all.
I used the light duty material bucket (remember I own a HD excavation bucket, actually 2 of them as well) and all of them are SSQA. I would never add the Green grapple to either round back excavation buckets anyway. The added weight of the Green grapple and the Vevor debtis forks is inconsequential for me as my lift capacity on either tractor I own, far exceeds what I'd ever pick up anyway.
I could not see buying an additional dedicated grapple attachment so I went the add on grapple route I already have enough 'stuff' in the barn as it is. I also like the fact I can remove the Green grapple quickly if necessary as well as the clamp on forks and use the bucket for other tasks like what it was designed for, material (dirt) handling.
They certainly are not for everyone but for my use, they are an ideal addition as are the clamp on debris forks. If the Green grapple and debris forks were for everyone, then no manufactirer would build of see dedicated grapples or heavy duty pallet / skind forks. In fact, clamp on forks on ANY light duty (single sheet bottom) material bucket and using them to move heavy objects or use them for prying something (like a stump loose from the ground) will impart a 'smile' in the bottom of the bucket and render it useless for dirt levelling tasks. I've repaired a lot of smiling, light duty buckets over the years where owners did just that and bent the lower sheet and why I own the HD double bottom sheet round back excavation bucket as well.
When you bend the lower sheet on any material bucket, you also pull in the side sheets and they most times require cutting them away to level the bottom sheet and then rewelding the side sheets again and none of that is a quick or cheap fix.
We have been clearing trails for many, many years but at the point, I have a wrist that no longer likes doing that. We have to switch to a tractor but we have used them on trails in the past. The rear hydraulics would be for a 3 point mower, or back blade. Front is for a grapple.
   / L5740 or some tractor #80
OK. Then add at least 2 sets of remotes on the rear. Way easier to add them at the same time than come back later and take everything apart to add another single.
If you can adjust top links and side link manually, you probably don't need any more than two. If you think you're going to want more, go for all three. I don't use anything behind that tractor that needs more than 2 remotes. Usually only need one.
I think we've beat this up enough.
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Fire Truck (A51692)
Fire Truck (A51692)
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
