Kubota L5740
   / Kubota L5740 #11
Kubota operator's, what quick connect system does there loader buckets use???
If you bother to read back a couple posts, I told you. Again... Kubota uses their proprietary 2 pin camlock SSQA disconnect that is compatible with all SSQA attachment plates from anyone except Deere and their 'Euro style; SSQA. I have both the Kubota 2 pin camlock SSQA as well as the ATI 2 pin camlock SSQA and they interchange 100% but I prefer the ATI as it's built stronger. Easy to tell the difference as well as the OEM will be orange and the ATI will be black.
   / Kubota L5740 #12
35 horsepower is a little small on a machine of that size, but not so much so it should be a problem. Outside of that, it's a low hour, cab, Grand L, it's a Cadillac of a tractor.
   / Kubota L5740 #14
That's a nice machine. My L3700 has about the same HP and has never been short on power. Maybe the hydraulic system could be stronger but if anything is too heavy for it, I use the skidsteer.. 40k and you can use it for 5-6 years and get back most of your money
   / Kubota L5740
Gee whiz, now a L5740 just showed up with cab, blower and more extra accessories for 47K with 700 hours and in the same town.
   / Kubota L5740 #16
Oh wow; that's pre-emissions, and damn near brand new!
I have no experience with the L-40, but they don't seem too different from the L3830 I grew up on, and that was one hell of a machine.
   / Kubota L5740 #17
Looks like it has loader brackets. Does it have a loader with it?
No rear remotes??
Much better tires for all-around use than the turf tires on the other one.
Look under and see if it's leaking hydraulic oil at the weep hole in the middle of the frame.
   / Kubota L5740
Yes and a few other attachments.
Specs are below-----------------------------------
The Kubota L5740 is a compact utility tractor with a 59 gross hp, 2.4L 4-cylinder diesel engine and a hydrostatic transmission. It features a semi-independent mid PTO linked to the rear PTO. The L5740 also offers both ROPS and cab variants (L5740HST and L5740HSTC).
Here's a more detailed breakdown of the L5740's specifications:
Engine:
  • Type: E-TVCS, indirect injection, 4-cycle 4-cylinder diesel.
  • Gross Horsepower: 59 hp.
  • Net Horsepower: 57 hp.
  • PTO Power: 50 hp.
  • Displacement: 148.5.
Transmission:
  • Type: HST Plus (3 Ranges).
Other Key Features:
  • 3-Point Hitch Capacity: Category I & II.
  • Cab Enclosure: Grand Cab Option Available.
  • Air Conditioning: Standard on Cab Models.
  • Heater: Standard on Cab Models.
  • Steering: Hydrostatic Power Steering.
  • Brakes: Wet Disc Type.
  • Clutch: Dry Type Single Stage.
  • Operating Voltage: 12 V.
  • Turning Radius: 9.2 ft.
  • Fuel Capacity: 14.3 gallons.
  • Operating Weight (with ROPS): 4,232.9 lbs.
  • 3-point hitch lift capacity: 2,976.3 lbs at 24 inches.
  • Dimensions:
    • Overall length: 10.54 ft.
    • Width (outside frame): 5.62 ft.
    • Height (to top of cab): 8.42 ft.
    • Wheelbase: 6.29 ft.
   / Kubota L5740 #19
Wonder where the grill guard is? Would be nice if they have it.
Needs rear remotes.
I’m not sure that it’s a great price, but then I get surprised every time I buy anything lately.
   / Kubota L5740 #20
Got a Kubota L3560 come up for sale near us for $40,000. 2021 with hours with 72 inch HD bucketL4479, 6 foot front mount snowblower 3 rear hydraulic remotes. Filled turf rear tires, Heat/AC, Bluetooth radio etc, etc.
If you have one, hows it been for you? Looks like the BH92 Backhoe got on it. If you got one, please comment on its use.View attachment 3474334
I don’t have one, but the L3560 is probably the nicest tractor in the 35hp range. The turf tires wouldn’t be my choice, otherwise that’s a sweet machine.
New Holland HM236 Disk Mower (A50515)
New Holland HM236...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
1262 (A50490)
1262 (A50490)
