Kubota L5740 error codes
   / Kubota L5740 error codes #1
ssseea
I was spreading gravel today and the tractor was fine then an error code of 90 flashed on the display and the tractor wouldnt go forward, it will only go into reverse. I tried to remove the battery cable to clear the codes, but it syill wont work. anybody had this problem?? Any help will be appreciated, I want to try to fix it myself instead of taking it to the dealer since Christmas is coming up soon.
   / Kubota L5740 error codes #2
Did you check the owners manual to see what the code indicated? That may help you determine if you can fix it yourself.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
Winchester Metal Sign (A57454)
Winchester Metal...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
