Kubota L5240 No Forward Only Reverse
   / Kubota L5240 No Forward Only Reverse #1
ChandlerW
Tx
John Deere 50 LP
Greetings everyone. I happened across an L5240 Kubota with the problem in the title of the thread.
I'm troubleshooting this for a friend.
So far I have switched the Check and High Pressure Relief Valves. Still will only go in reverse.
I swapped out the Forward and Reverse Proportional Valves. Still will only go in reverse.
I switched the cable connectors on the Forward and Reverse Proportional Valves, and now pushing the pedal forward will make the tractor go in reverse. Swap them back and pedal operates as normal. Push back and the tractor goes back, push forward and it doesn't go anywhere.
I think the valves are good and the pedal potentiometer is good.
The next thing I tried is Adjusting By Electronic Instrument Panel.
I figured maybe the ECU needs to relearn the pedal position.
I get in to HST-ADJ Mode and STEP-01 is displayed.
I set the cruise control lever to maximum forward position, the HST Response Dial to Maximum, the the HST Pedal to Maximum Forward Position.
Step-02 is displayed.
As soon as I move the HST Pedal back to center Step-01 is displayed.
I believe Step-02 is supposed to remain displayed.
There are more steps but I can't get past Step-01.
Anyone have experience with this?
   / Kubota L5240 No Forward Only Reverse #2
Often this is a loose wire at the HST forward/reverse solenoid under the tractor. Wiggle the connections.
Mowing brush is hard on this connection.
Connections are good. It seems that the pedal maximum travel is not being stored.
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
PALLET OF HYDRAULIC HOSES (A50854)
PALLET OF...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
