Kubota L5030HSTC
   / Kubota L5030HSTC #1
rvtgr8
United States
Kubota L5030HSTC
Just bought my wife a Kubota 5030. Can anyone direct me to a good general manual or repair guide. It is a 2006 with less than 300 hours. I have not had the time to review the hydraulic options on the tractor, but they seem somewhat limited. I have the joy stick for the front and lift controls for the back. Do they sell additional control blocks that stack somehow? I am new to all of this hydraulic stuff as my previous tractors have all been very old and straight forward machines. Any advice would be appreciated.
   / Kubota L5030HSTC #2
If you are asking can you add a valve to the back remotes, then yes.
If the valves are a stacked valve, just find the manufacturer and order whatever type spool you desire, and connect them together.
If the remote valve is a mono block valve, then you can add another valve to that valve in series if it has PB, or replace the current remote valve with, say a 4 spool valve with PB, and then add your old valve to the PB port.
Mono block valve
http://www.surpluscenter.com/item.asp?item=9-7978&catname=hydraulic
Stacked valve
http://www.surpluscenter.com/item.asp?item=9SV-4-Y&catname=hydraulic
   / Kubota L5030HSTC #3
Your tractor is fundamentally new. Mine has over 1000 hrs and continues running fine. You can purchase a Work Shop Manual from Kubota covering the cab and tractor, neighborhood of $100 if I recall properly. Do you have ANY hydraulic ports at the rear of your tractor??? As many as three could be installed. Give more info regarding what your wife wishes to do with it....it's a sweet tractor, no toy. What else, 4wd, FEL, any implements yet??
:welcome:
There are numerous threads where the L5030 is discussed. Suggest you use the SEARCH feature of TBN and look thru those posts. Much good info there...come back to us with questions.
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2019 FORD F-250 (A52472)
2019 FORD F-250...
2013 MACK CXU (A52472)
