KUBOTA L5030 PTO Not working
   / KUBOTA L5030 PTO Not working #1
VIC EADIE
Kubota L5030
When i reverse into long grass the PTO stops working. Does anyone know why I can`t get it to engage.
   / KUBOTA L5030 PTO Not working #2
HST model? Are you mowing? Does it engage when not under load?
If it doesn't engage at all, the lever may be disconnected. If it slips under load, you may have a burned up pto clutch or a filter is so plugged the pto clutch doesn't have enough pressure to operate.
   / KUBOTA L5030 PTO Not working #3
Welcome to TBN. As slowzuki said check your cable from the PTO to the lever that it actuates. This lever controls a hydraulic valve that operates a clutch pack for the PTO. So if the pressure is low or the valve is not operating thats the place to look. More details would help in diagnosis.:thumbsup:
Zero Turn Mower (A48082)
Zero Turn Mower...
1274 (A50490)
1274 (A50490)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
