KUBOTA L5030 PTO Not working
   / KUBOTA L5030 PTO Not working #1
VIC EADIE
Kubota L5030
When i reverse into long grass the PTO stops working. Does anyone know why I can`t get it to engage.
   / KUBOTA L5030 PTO Not working #2
HST model? Are you mowing? Does it engage when not under load?
If it doesn't engage at all, the lever may be disconnected. If it slips under load, you may have a burned up pto clutch or a filter is so plugged the pto clutch doesn't have enough pressure to operate.
   / KUBOTA L5030 PTO Not working #3
Welcome to TBN. As slowzuki said check your cable from the PTO to the lever that it actuates. This lever controls a hydraulic valve that operates a clutch pack for the PTO. So if the pressure is low or the valve is not operating thats the place to look. More details would help in diagnosis.:thumbsup:
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
1267 (A50490)
1267 (A50490)
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
