Kubota L4760 no start.
   / Kubota L4760 no start. #1
firemandan774
Kubota 4760 HST
Hello .
I have a 2013 Kubota 4760 it has only 120 hours on it. I am having some problems with it. The tractor does not get lots of use and sits for some times over a month or more without running. I found that the radio draws the battery down so I take the battery cables off at the battery to keep the battery from discharging. I have noticed that the negative cable was not tightening down to the post all that well. I replaced the negative cable on the tractor and it fits tight now. I charged up the battery and boosted the tractor . It will turn over but wont fire. It seems that its not getting fuel. I had it running no problem the weekend before it ran fine when i put it away. Could boosting the tractor cause a fuse to interupt and cause the fuel system to not allow fuel to flow. I checked the water seperator and all good there. I changed the fuel filter last winter so it should be good. I have fuel flowing to the fuel filter and can here what appears to be a fuel pump clicking with the key switch on. I had difficulty finding the fuse panel but since have found there location in the manual. I was told that there is some sort of solenoid that keeps the fuel from flowing to injector pump and that it could be a fuse or faulty solenoid. Any assistance would be great.
Thanks Dan.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
Toro Z Master Mower (A50324)
Toro Z Master...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2000 Dnya RGN (A49461)
