Kubota L4760 leak down.
   / Kubota L4760 leak down. #1
guyrich
Brentwood, New Hampshire
Kabota
Recently purchased Kubota L4760 with loader and BH92 hoe. Approximately three days the stabilizer are 10 inches off the garage floor. I left the dipper unlatched and it was just about to rest on the truck. This leak down normal for Kubota?? I had purchased a smaller Kubota and had the same experience. I only owned it for a few months as it was a little to small. I like the tractor and can live with it if this is normal.
Guy Rich
   / Kubota L4760 leak down. #2
Guy Rich
Yes, that's pretty normal for this type of equipment, regardless of brand. Hydraulic cylinders with check valves don't leak down but are more costly and probably not economically justified in occasional use equipment like this. Likewise, higher precision tolerances in the cylinders as found on construction equipment is much more costly.
   / Kubota L4760 leak down. #3
Resurrecting an old thread here, but new L6060HST with BH92 used for about an hour last night and overnight the stabilizers dropped to the ground. The last bit took about an hour to go from probably a 60 degree angle to the ground (tractor sitting where my security camera picked up the action). Quite annoying as if I forget to pull them up before I move the tractor I'm going to have a mess of my barn.
I noticed when they delivered it when I parked it, I locked the hoe in place. When I came back outside like 3 hours later the hoe was sitting against the lock.
All the posts I see on here say this is normal behavior. I did not notice any leak down when the tractor was running but honestly haven't used it that much yet (it was literally 0F here last night). However, overnight for things to drop seems pretty fast. Could this be an indication of an issue, and if so what should I look for? I checked around the tractor last night for leaks (found one on the 3rd function install) but didn't notice anything on the backhoe. I'm wondering if I should get after my dealer about this or just let it go if it is "normal"?
If this is just normal, how do others deal with keeping them up? Thinking maybe some sort of rope or strip loop joined to length I can quickly put on them and take off at this point.
PS: Interesting story, I asked the fellow (super nice guy) that delivered it if they leak down when you detach them and he said no. In my case now it is still attached. But, this is the same fellow that told me that I didn't have to reconnect the power beyond hose going to the backhoe back to the tractor and I could remove those lines with the tractor running. :confused2: I feel bad for people that are not equipment savvy or spend time on forums like this. I suspect years ago before the Internet people must have broken way more stuff.
   / Kubota L4760 leak down. #4
I don't know in your situation if it's normal or not. I can tell you I got a mf 1531 and the loader has leaked down every since I've owned it. I got a 40+ year old allis Chalmers. I have raised the loader up to make more room to cram things into my machine shed. That loader on the allis Chalmers will stay up indefinitely. So I don't know what to think.
   / Kubota L4760 leak down. #5
mljenkins, is this new equipment? If so, I'd ask the dealer. Even if they say that it's OK they'd kind of be on the alert that you're concerned; if it should worsen (not necessarily assured, but possible if there IS some sort of defect) then they would likely be a bit more responsive (hard to dismiss something the second time around).
Seems that the general rule of thumb is that everything tends to leak down and it's really the rate that is of concern. In the case of a backhoe's stabilizers they're not typically down in the same spot for a long time during operation in which case any leak down isn't likely going to be detected (if one finds that one is "detecting" it, having to adjust during operation, THEN it starts to become/is an issue. Parked and not in use, well, not so much. I make it a habit to check the state of all attachments when going to first operate my equipment: sometimes I forget and I realize that it's MY fault.
I have a check valve on my NX5510's top link to help keep stuff like my box blade from drifting down, something that absolutely WOULD happen fairly noticeably when operating with its weight (1,200 lbs).
   / Kubota L4760 leak down. #6
Yes new equipment just delivered yesterday. The sales guy I dealt with was out today so I'll try again tomorrow.
In relation to what Phillip mentioned, I had a NH WM55 that I traded. The loader would never leak down. Even with my box blade at 750# on the 3-point it wouldn't move much after a few days (I never left it raised intentionally so not sure how long it would have stayed). So at this point I'm just wondering if the valves on the backhoe are just really crummy. I've never owned a backhoe before so I wasn't sure what to expect. I figured a little leak down would be normal, but for the stabilizers to be on the ground by morning I thought was excessive.
Matt
   / Kubota L4760 leak down. #7
Matt,
Yes - the stabilizers will leak down overnight. The valve stack is a standard 7 spool unit and the only thing that keeps the legs up is the clearance (or lack of) between the spool and the valve body. These valves are good quality but they have to have this clearance in them or you could not move them manually or afford to buy them.
There is no check valve on the stabilizer circuit so if eliminating creep is important to you, install an alternating check in the circuit on each side (L/R) and you will not see any creep of the stabilizers as the check valve will isolate the cylinder from the valve when no fluid is flowing in or out.
You may tell the dealer you want another valve but I will tell you the result will be the same as they all will have some clearance in them. You may get one that is slower / more acceptable to you, but as it wears, the clearance increases....
And when the dealer files a warranty claim and the valve is recalled and tested, the claim will be denied as it meets the manufacturing spec agreed to by Kubota.
Sorry to sound like your Dad but I did this for many years and know the drill.
Good luck!
YC
   / Kubota L4760 leak down. #8
What these other folks said. Having the outriggers leak down overnight is completely normal. As for "dealing with them", it's not a safe practice to leave farm equipment parked unattended with attachments elevated solely on the hydraulics, whether it's your loader, backhoe or a 3 point implement. You don't know when someone who doesn't know any better (a child or grandchild, for example), will come across your equipment and start playing with the controls. Always drop any hydraulically operated attachments fully to the ground (or pin them in position) when you shut down for the day. Your tractor and/or backhoe operators manual probably says something similar in the Safety Precautions section.
   / Kubota L4760 leak down. #9
Matt,
Thanks for the explanation. I would rather not have it worked on if this is normal over time as the last thing I want is to introduce new issues.
As for the comments on lower the hydraulics, I always do so for the loader and three point for the reason of safety. Thanks for pointing out that aspect for the backhoe because I honestly never thought about it with regards to the stabilizers (not owning one until now). I think I’ll likely just try to move some things around so I can either lower them when I am done for the day or I will make some sort of strap to hold them. I saw where someone on the forums had mentioned making a latch for another brand of backhoe so perhaps it would even be possible to devise something better over time. Perhaps a warm rainy day project...
Thanks again for all your comments. At least I know now not to be overly concerned with it. I used it lightly about half an hour this evening and did not notice anything abnormal with functions or the stabilizers using it.
   / Kubota L4760 leak down. #10
Hey, I forgot to lower my 3 pt arms. It was an honest goof. I had a bale carrier and big round bale on. (Probably 1400 lbs more or less). The arms never moved. That on my old allis Chalmers. That's what I got going on, don't know how it applies to your situation or if it even does.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
1263 (A50490)
1263 (A50490)
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
