Kubota L4330 vibration
   / Kubota L4330 vibration #1
banjerpicker
Just bought a used L4330 2007 model. Seems to have quite a lot of vibration at about 1500-1800 RPMs. It's my first HST. Is this normal? Also own L2850 and M4700. If not, someone has suggested that there could be air in Hydro lines. I have the owners manual but I see no solution to removing air except to work the loader, which I have done....any thoughts....Thanks Larry
   / Kubota L4330 vibration #2
Doesn't seem normal to me. This is with nothing on the PTO, right? Any air in the hydraulics would likely make a lot of noise, but probably at all RPMs, and I don't see how air could cause vibration. What would you estimate the frequency of the vibe to be? Just order-of-magnitude, as in very high-pitched like engine speed or higher or very low like PTO or wheel speed?
- Jay
   / Kubota L4330 vibration #3
No it's not normal, I had an L5030 and it was really smooth; unfortunately I don't have a clue. brain55 is a tractor mechanic with a long history on Kubotas, so if he doesn't show up, you might check with him, seems like a pretty helpful guy.
Just bought a used L4330 2007 model. Seems to have quite a lot of vibration at about 1500-1800 RPMs. It's my first HST. Is this normal? Also own L2850 and M4700. If not, someone has suggested that there could be air in Hydro lines. I have the owners manual but I see no solution to removing air except to work the loader, which I have done....any thoughts....Thanks Larry[/QUO
My Kubota mechanic came out and drove my tractor and suspects that the HST is showing a slight wear on the plates that the pump goes up against. That is the best way I can describe. He said he had rebuilt HST on small tractor that owners overworked hauling gravel up a big hill..as one example. Not bad enought to replace the transmission modules. He said I would probably never wear it enough to get it torn apart and repaired. At first he never felt the vibration, so that seemed to be better. I put a 6ft finish mower on it and used it to mow for the first time and never really noticed the vibration.
I'll update if anything changes.
Thanks Larry
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2023 Kubota U27-4 (A50120)
2023 Kubota U27-4...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2022 John Deere 6135E (A50120)
2022 John Deere...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
