Kubota L4330 Parking Brake
   / Kubota L4330 Parking Brake #1
Atchuuu
Kubota L4330 HSTC
I have left the parking brake on a couple of times while running my tractor. The indicator light does not light up when I depress the brakes. I don't have a WSM for the tractor so I don't know if the bulb is out or there is an adjustment on the pedal itself.
The tractor still operates with the brakes on so it is possible they are worn or are not adjusted correctly as well.
If you have any advice, tips or opinions please post.
   / Kubota L4330 Parking Brake #2
Apply the brake on a hill and see if it holds it. If it doesn't hold, then it needs some repair or adjustment
   / Kubota L4330 Parking Brake #3
from WSM:
Parking Brake Switch Panel and Wiring Harness 1. Disconnect the connector from the parking brake switch after turning the main switch OFF. 2. Turn the main switch ON and connect a jumper lead between the connector terminals of wiring harness. 3. If the parking brake indicator lamp does not light, the panel circuit or wiring harness is faulty.
Here's a picture from a different section covering the Parking Brake.
Hopefully you'll find the info helpful.
Good luck and report back what you find.
Thank you Moship. Very nice of you to post the photos from the WSM.
   / Kubota L4330 Parking Brake #5
The brake pedals themselves are usually easy to adjust with the supplied turnbuckles. IF the turnbuckles/locknuts aren't too corroded!
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
43029 (A51691)
43029 (A51691)
John Deere (A50322)
John Deere (A50322)
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
