Kubota L4200GST tractor - question about the operation of the gearbox.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #1
licz3
Kubota L4200
I have a question for users of the Kubota tractor with GST gearbox.
I have never come across this kind of gearbox and have owned a Kubota L4200GST since November.
How should a tractor behave when, for example, I gather a bucket of soil - is it normal that in higher gears the tractor simply stops as if it would disengage the clutch? The engine does not choke, the wheels do not turn and the tractor simply stops. The same is true when, for example, I am plowing - if I do not downshift to 3 or lower, the tractor stops.
Is this all normal or maybe some problems with the gearbox?
   / Kubota L4200GST tractor - question about the operation of the gearbox. #2
Not normal you need a clutch adjustment or hydraulic clutch adjustment. Take it to a dealer and give him your wallet.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #3
Sounds like the clutch needs adjusted or replaced.
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2018 Ford F-350 (A55973)
2018 Ford F-350...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
