Kubota L4200 GST Transmission Fluid Leak
   / Kubota L4200 GST Transmission Fluid Leak #1
Markgcr
Wendell, NC
Kubota L4200
I have a late 90's Kubota L4200 Glideshift 4 wd tractor. I warmed it up today and moved it out of the barn and a few hundred yards up to the house and then I noticed that I had transmission fluid dripping out of the tube that houses the propeller shaft that runs under the oil pan and between the rear of the engine block and to the back of the front axle. This tube is in two sections and transmission fluid is emptying itself out of the joint in this cover tube which is pretty much half the way down the oil pan.
How is transmission fluid getting into this area. It has been leaking out for over an hour now. I don't think this is good !
   / Kubota L4200 GST Transmission Fluid Leak #2
I have a late 90's Kubota L4200 Glideshift 4 wd tractor. I warmed it up today and moved it out of the barn and a few hundred yards up to the house and then I noticed that I had transmission fluid dripping out of the tube that houses the propeller shaft that runs under the oil pan and between the rear of the engine block and to the back of the front axle. This tube is in two sections and transmission fluid is emptying itself out of the joint in this cover tube which is pretty much half the way down the oil pan. How is transmission fluid getting into this area. It has been leaking out for over an hour now. I don't think this is good !
It is leaking out of the the seal for the front drive shaft following the shaft through the cover out to the lowest point
Yes good thinking. I have the shop manual and removal of the front prop shaft and cover tube seems pretty straight forward. I haven't found the section that discusses replacement of this oil seal. Have you replaced that seal before?
I have never seen a seal fail like that before but my experience is mostly on motorbikes and cars.
thanks
PS I found this Service Bulletin which might be my problem..I need to check my SN
SERVICE
BULLETIN No:
Series:
Fail Code:
Date:
Issued by: AG001 - 98
L-series
FA07
01/23/1998
Raymond Marmillod
National Service Manager
Subject: Oil Leak at the Front Axle Propeller Shaft Seal
Model(s): L2900, L3300, L3600, L4200 Tractors
Serial Ranges: L2900DT,GST
L3300DT,GST
L3600DT,GST
L4200DT,GST ~61866
~54019
~56733
~57185
Service Information:
We have received reports of transmission oil seepage into the clutch housing past the front axle propeller shaft seals (Item #f). This is caused by the sleeve (Item #d) moving out off position and causing the seals (Item #f) to leak.
To alleviate this problem, Kubota has designed a spacer (Item #1) that will prevent the sleeve
(Item #d) from moving out off its position.
Note: All tractors built after the S/N indicated above have the new spacer already factory installed.
Parts Information:SPACER AND O-RING KIT P/N TA040-98000
KIT CONTENT
ITEM # PART NUMBER DESCRIPTION QUANTITY
1 *TA040-14720 Spacer, Propeller Shaft 1
2 *TA040-82180 O-ring 2
3 *TA040-98010 Instruction Manual 1
ADDITIONAL PARTS TO ORDER IF NECESSARY
a Propeller shaft cover
b Coupling
c Propeller shaft, front
d 53582-53520 Sleeve (Order only if needed) 1
e Spring pin
f 09500-25388 Oil seal (Order only if needed) 2
g Collar
h Ball bearing
i Propeller shaft
j Screw
Warranty Information:
Normal warranty apply to tractors within the standard warranty term.
Labor ROPS Tractors Labor Cab Tractors & L35
Code Description Hours Code Description Hours
TRMn-11 Steam clean for servicing 1.8 TRMn-11 Steam clean for servicing 1.8
TRCb-21 Front drive shaft assy, Rear side R/R 5.0 TRCb-21 Front drive shaft assy, Rear side R/R 8.6
* Install the spacer and o-ring repair kit only to tractor models indicated that are experiencing concerns with oil leakage at the propeller shaft.
* This repair is classified under failure code "FA07." Please state failure code "FA07" and service bulletin "AG01-98" under details of failure section on the warranty claim.
   / Kubota L4200 GST Transmission Fluid Leak #4
That was easy to find. Hope it works out for you.
   / Kubota L4200 GST Transmission Fluid Leak #5
I developed the same problem. Have you had it repaired?
Yes I bought the kit and fitted it. It worked fine. The local dealership wanted to change the oil seal as well. That is expensive to do as the machine needs to be split in half. If you can do the job yourself then have a go. Do not mess with the recessed oil seal and buy yourself a decent roll pin drift set.
   / Kubota L4200 GST Transmission Fluid Leak #7
Thank you for the response. I received the new shaft (TA040-1420) and two O rings Yesterday . I'll need to find why the manual (TA040-98010) was not mailed. I hope this works because the last shop in WV I talked to charged $8500 to replace the seals.
   / Kubota L4200 GST Transmission Fluid Leak #8
I was told the manual is no longer available. Do you remember if the manual suggested anything out of the ordinary or even better if you had a copy. Thank you very much for all your help
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
