Kubota L4060 Warning light question
/ Kubota L4060 Warning light question #1
L4060HSTC
Syracuse, NY
L4060HSTC
First of all I posted this previously in the wrong area and have moved it here in hopes of additional responses from you members.
Just took delivery of a new L4060HSTC, factory 3rd functrion and all the cold weather CNY artic options (all defrosters, front & rear lights etc...) and have an issue with the master warning light (as named by the owners manual).
The light in question is a red triangle with an exclamation point within same and my problem is that although it is too warm to utilize the glow plugs at this time if I leave the key in the "On" (2nd click) position for more that 2-3 seconds while messing with the radio or what not, and then start the tractor the warning light will flash until shut down.
Now conversely if I start the tractor "like a car" and just hop in an turn the key starting same immediately the warning light never comes on. (it is about 60 degrees out today and glowplugs are obviously not needed)
I talked to three dealers and was told the following:
1) "Just start it like a car, no warning light no problem"
2) "Ignore it"
3) "The is the system telling you that you do not need to delay starting"
Bottom line is that I cant take a chance "ignoring" something or not correcting the issue with a $40K tractor!! ANY HELP WOULD BE GREATLY APPRECIATED!
/ Kubota L4060 Warning light question #2
That is the "Safety Alert" warning indicator.
On the Lxx40 series that warning indicator means there is a problem with the HST. Do you have an Operator's Manual?
I would not operate the Tractor any more than needed to get to the barn. Then call Kubota.
Maybe it's nothing more than a "buckle your seatbelt" alarm on your model.
Why risk causing more damage then necessary?
2019 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2019 CATERPILLAR...
Kuhn FC400RG (A60462)
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
Honda utv cart (A56859)
Honda utv cart...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
