Kubota L405 tractor
   / Kubota L405 tractor #1
Jed1277
L405DT Kubota
Hi I have a Kubota L405 4 wheel drive that just stopped while being driven. It didn't run out of fuel, when trying to re start it, it sounds like it is trying to start on one or two cylinders but will not start. Does anyone have any suggestions. Thanks.
   / Kubota L405 tractor #2
You might check your feed lines from the tank to the filter. I had the float come apart and little pieces came up till it hit a joint and restricted fuel flow. My tractor acted like it had injector issues. Would run at an idle but barely.
   / Kubota L405 tractor #3
I had some wax drop out of solution on the JD 4010 tank and partly blocked the outlet. Had to siphon fuel out of the tank and then use a grabber tool to get the wax glob off the outlet. It was the first and only time I used the red dyed diesel fuel.
Ralph
   / Kubota L405 tractor #4
Make sure the fuel tank cap isn’t plugged. Try running leaving the cap off. Also use diesel power service fuel additive.
1993 UTILITY TRAILER MANUFACTURER 45 FLATBED T/A TRAILER (A58214)
1993 UTILITY...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
More info coming soon! (A56858)
More info coming...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
