Kubota L405 tractor
   / Kubota L405 tractor #1
Jed1277
L405DT Kubota
Hi I have a Kubota L405 4 wheel drive that just stopped while being driven. It didn't run out of fuel, when trying to re start it, it sounds like it is trying to start on one or two cylinders but will not start. Does anyone have any suggestions. Thanks.
   / Kubota L405 tractor #2
You might check your feed lines from the tank to the filter. I had the float come apart and little pieces came up till it hit a joint and restricted fuel flow. My tractor acted like it had injector issues. Would run at an idle but barely.
   / Kubota L405 tractor #3
I had some wax drop out of solution on the JD 4010 tank and partly blocked the outlet. Had to siphon fuel out of the tank and then use a grabber tool to get the wax glob off the outlet. It was the first and only time I used the red dyed diesel fuel.
Ralph
   / Kubota L405 tractor #4
Make sure the fuel tank cap isn’t plugged. Try running leaving the cap off. Also use diesel power service fuel additive.
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
New Long Forks (A53002)
New Long Forks...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
