Kubota l3940 help
   / Kubota l3940 help #12
My 3240 hst has a clutch also.
Must have made that switch going into the 60 series then. Do the 40s have a electro-hydraulic actuated PTO? PTO engagement with a manual lever & the clutch was the only use for the clutch on my old L3200. No need for a clutch at all on my L4060 HST with an electro-hydraulic PTO, so it doesn't have one.
   / Kubota l3940 help #13
Mine has the manual lever. I think the newer 3240's had a switch to engage the PTO, mine has the sliding lever...mine was bought in 2007
   / Kubota l3940 help #14
There are two different ways the rear PTO engages on a L3940 or any Grand L40, both have a clutch on the left hand side. The earlier version designate L3940 uses the traditional manual lever. The newer model designated as L3940-3 has a yellow rotary electrical switch to actuate the rear PTO and the pressure to the pto clutches (not the clutch by left foot) is controlled electro-hydraulically and RPM dependent.
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
PALLET TOTE OF MISC CABINETS (A58374)
PALLET TOTE OF...
2000 HAULMARK K716BT-WT 7' X 16' CARGO TRAILER (A52708)
2000 HAULMARK...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
PARKER 250BU GRAVITY BOX (A52708)
PARKER 250BU...
Year: 2017 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 2 Door C... (A56858)
Year: 2017 Make...
