Kubota L3940 GST lever/shuttle shift lever
   / Kubota L3940 GST lever/shuttle shift lever #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
My 2006 L3940 levers for GST and shuttle shift getting sticky. I have used WD40 and it restores smoothness but only for a week or so.
What do you guys recommend for a longer-lasting solution or is there a more serious problem lurking?
   / Kubota L3940 GST lever/shuttle shift lever #2
I use wd40 for a lot of things, but it's not really designed as a lubricant, and certainly not long lasting. Maybe try a spray type grease or chain lube. Motorcycle chain lube stays put and lubricates well.
   / Kubota L3940 GST lever/shuttle shift lever #3
Take a look at what the levers are moving. When I looked at the Kubota M59 loader levers I expected to see a lot of mechanical linkage that I could lube, but what I found instead was a maze of stranded cables in covers - like bike or motorcycle cables. Those take a completely different type of lube strategy if you want to do them right.
BTW, getting the knobs off of the levers so I could get down to the pivots took some thought. The rubber knobs are pressed on, but mine hadn't ever been taken off. Heat helps and I even considered cutting them off, but here is what worke. I've had them on and off several times now.
If you take any panels off, I recommend extending the wiring to all electric controls. Kubota is really stingy with wire, and only uses just enough to slip a child-size hand underneath to disconnect the fasteners. Adding a few inches of wire leads throughout turns a hassle job into a pleasure.
rScotty
rScotty
   / Kubota L3940 GST lever/shuttle shift lever #4
What Rj said wd40 works well for cleaning a surface but not a lubricate. try some spray lube light grease that will stick to the surface
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
VINTAGE GAS PUMP (A58374)
VINTAGE GAS PUMP...
