Kubota L3902 engine noise
   / Kubota L3902 engine noise #1
DiWil35
Texas
Mitsubishi D1500
I have a Kubota L3902 HST with 200 hours, the tractor runs perfectly fine but I notice a sound from the engine and wondering what it could be.
I revised this post
The sound I am hearing from the engine is a tapping sound that is slightly deep, it isn't loud like a banging sound but it is enough where I can notice it. It is most noticeable when the engine is cold during a cold start but goes away when the engine warms up.
There have been times when the engine is still warming up such as moving the tractor or using the mower I would notice the tapping sound from the engine suddenly disappear.
Any ideas? Has anyone every noticed a engine noise like this before?
   / Kubota L3902 engine noise #2
What kind of frequency with the tapping sound?
WAG is solid lifter slop & may be reduced with valve adjustment.
Is the engine over-full of oil?
Another thought is using a long handle screwdriver up to your ear and touching various (obviously stationary) parts of the running engine or using an engine stethoscope to localize the sound to a particular engine area
The frequency is directly linked to the rpm of the engine, I want to say the noise seems to be on the ignition or power stroke of one of the cylinders where when a cylinder fires I hear a tap.
Engine oil is at a normal level or right at the full mark.
I used a wooden rod and listened to different places on the engine. The loudest area was the fuel injector pump, particularly near where the house exits the pump I can hear a loud sound. Around the bottom of the engine where the oil pan is I hear a slight tick sound but it isn't that loud.
I recorded mp3 audio of the tapping noise from the engine but I haven't figured out how to attach it to this post
   / Kubota L3902 engine noise #4
I would vote for the easy bit first adjusting the valves. If that doesn't fix the noise then you can go down the rabbit hole of piston slap etc.
Maybe others can chime in here as well
Thank you for the feedback
   / Kubota L3902 engine noise #7
Valve adjustment on most Kubota's will be a dealer item. Not a backyard wrench thing.
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A57453)
2008 Hino 268...
2007 John Deere 5225 56HP Utility Tractor (A55973)
2007 John Deere...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2021 TAKEUCHI  TB260 (A58216)
2021 TAKEUCHI...
