Kubota L3901 sluggish in 2nd gear
   / Kubota L3901 sluggish in 2nd gear #1
kbernard
Kubota L3901
I have a Kubota L3901 with 136 hrs. It has become sluggish in 2nd gear and will not climb a hill. I changed the fuel filter, emptied the separator and cleaned, turned valve on to separator and getting good flow. The hydraulic oil is clear.
Other than cleaning the elbow at the fuel filter any other suggestions.
Thanks
Kendall
   / Kubota L3901 sluggish in 2nd gear #2
I would be tempted to check hydraulic fluid level, not sure if there is an adjust in the linkage of the hydrostatic pedal but that would come next.
I did check the hydraulic fluid level and it is where it should be. The fluid is also clear. There is no play in the pedal. Any other suggestions would be appreciated.
2025 JMR 44in Bucket Skid Steer Attachment (A49346)
2025 JMR 44in...
Flatbed Truck Body (A48081)
Flatbed Truck Body...
2011 MCI D4505 TANDEM AXLE PASSENGER BUS (A45679)
2011 MCI D4505...
2010 John Deere 5105M 4WD Tractor (A49251)
2010 John Deere...
2013 MACK CHU613 DAYCAB (A48992)
2013 MACK CHU613...
2014 PETERBILT 367 (A48992)
2014 PETERBILT 367...
