Kubota L3901 sluggish in 2nd gear
   / Kubota L3901 sluggish in 2nd gear #1
kbernard
Kubota L3901
I have a Kubota L3901 with 136 hrs. It has become sluggish in 2nd gear and will not climb a hill. I changed the fuel filter, emptied the separator and cleaned, turned valve on to separator and getting good flow. The hydraulic oil is clear.
Other than cleaning the elbow at the fuel filter any other suggestions.
Kendall
   / Kubota L3901 sluggish in 2nd gear #2
I would be tempted to check hydraulic fluid level, not sure if there is an adjust in the linkage of the hydrostatic pedal but that would come next.
I did check the hydraulic fluid level and it is where it should be. The fluid is also clear. There is no play in the pedal. Any other suggestions would be appreciated.
1998 C6500 Chevy, 3126 Cat Engine (A47371)
1998 C6500 Chevy...
2018 JLG Skytrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A46683)
2018 JLG Skytrak...
Lexion C508-30 (8) Row Corn Head (A49339)
Lexion C508-30 (8)...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45679)
2016 FREIGHTLINER...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2019 580SN3 S/A Pressure Washer Trailer (A46683)
2019 580SN3 S/A...
