Kubota L3901 HST vs L4701 HST options
   / Kubota L3901 HST vs L4701 HST options #11
...I read online that a lot of people like the non-QA loader better...
Wow, where? I got to meet like minded people. I thought I was the only one?!? :p
How much land do you have and what are your plans for the tractor? Also, what is the price difference. Easy for us to tell you to spend more money on a bigger tractor you may or may not need.
If your time is worth money and you have less time than money, yea, go big. That is IF you have plenty of room to play with the bigger tractor. If you have tight spaces to get in and out of (or lots of tree to maneuver around)... don't go big. :2cents:
   / Kubota L3901 HST vs L4701 HST options #12
Pretty much have it narrowed down to these two tractors. I've test driven a couple of them but I'm just not sure if the difference in size & price is justifiable. What options are there for the two tractors & their respective FELs? I know there's a quick connect FEL which is not recommended, correct?
I think there is some confusion here. Are you asking about removing the FEL from the tractor or removing the bucket from the FEL?
   / Kubota L3901 HST vs L4701 HST options #13
I loved the SSQA on my L3200. Never felt motivated to remove the loader despite hearing it was an easy 5 minute job.
The bigger machine is a bigger machine. More traction, more loader lift, more power, more fuel consumption, less manuverability.
I ended up upgrading from my L3200 to a L4060 for a cab & bells & whistles. More weight & lift capacity is nice, but double the weight negates the extra 8hp I got. I avoided the underpowered (for weight) L3560. Occasionally regret not getting a L4760, but how for the money was a bit much.
   / Kubota L3901 HST vs L4701 HST options #14
I would not want a tractor without SSQA.
As far as the loader. I leave my loader on all winter for snow plowing.
I remove it in the summer for finish mowing, brush mowing and reinstall it when I need it like every other attachment.
   / Kubota L3901 HST vs L4701 HST options #15
If you are mowing with the tractor having a removable loader is invaluable. I also would never buy a loader without the SSQA as I change the buckets/forks/grapple a couple times a week. In my opinion both are worth the price.
   / Kubota L3901 HST vs L4701 HST options #16
I could be wrong, but I believe the current L01 series has one type of loader mount to the machine, which comes off easily just like the Grand L60’s. The bucket may come in pin-on style or SSQA.
I have never felt the need to remove the loader in many years of use across 2 tractors. I FREQUENTLY use the SSQA to switch front implements and highly recommend getting SSQA .
Sorry guys I don't think I typed that correctly. I meant I've heard the QA loader is better & the pin on loader is the one to stay away from, correct? I've test driven a few & while I think I'd like the extra Hp & capabilities of a larger tractor, the mountain property is going to be my limiting factor due to the steepness & trees so the L3901 is prob. the winner for me.
   / Kubota L3901 HST vs L4701 HST options #18
I had the quick removable loader on my L3200. At least I assume it was quick removable. I never took the 5-10 minutes to find out. Dumping the bucket or forks off the SSQA was always plenty for me. Never feel the need to remove the whole loader.
The QA/SSQA loader is stronger than the tractor. Even with plenty of ballast (rotary cutter + a couple hundred lbs of stuff on the back of the rotary) it was sketchy as **** when doing a big lift. And by big lift I mean 200-300lbs + a load a few feet out over the rated 1,200lbs. The tractor stability is definitely the week link here.
No clue on the non-QA loader. But definitely get the SSQA. Makes dropping the bucket or grabbing forks a breeze. Makes any need for QA mostly moot in my opinion.
   / Kubota L3901 HST vs L4701 HST options #19
A QA loader is the “only” way to have it. Those of you who only have a bucket loose like 80 percent of the FEls usefulness.
   / Kubota L3901 HST vs L4701 HST options #20
....I meant I've heard the QA loader is better & the pin on loader is the one to stay away from, correct?...
:confused2: :confused3: Part of the problem is what is called what!! There is Quick Attach Loaders which is on 95% (pulled that numbet out of my butt :eek:) of all tractors. Then there is Quick Attach Buckets/forks which are usually Skid Steer Quick Attach complaint but John Deere has their own Quick Attach Buckets/fork and even Kubota had their own version of Quick Attach buckets that you had to insert a pin for the bottom of the bucket. (see photo)
Personally, since you move the load 4" out in front of you, you loose 10-15% (# came from the same place) of what your tractor could lift with a Pin on bucket. I have no need for forks... I got clamp on forks but only use the 3 point hitch forks (top and tilt, helps) to move my firewood. Besides, the 3ph is almost twice as strong. That's just my take...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
Bighorn 450 UTV (A57453)
Bighorn 450 UTV...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
Deere 310L (A53317)
Deere 310L (A53317)
