KUbota L3901 400 service
/ KUbota L3901 400 service #1
Ryansweatt2004
West gardiner maine
2017 kubota L3901 HST
Hey everyone, my 2015 L3901 is right about at 350 hours and I'm sure with all the side jobs I have planned along with work around my house that I'll be up to the 400 hour service by the end of summer or mid fall at very least. One question I have though, from looking through my kubota manual it says to use either 10w30 or 15w40 engine oil? Does it matter which and what brand of oil is everyone using?
/ KUbota L3901 400 service #2
Personally I use Delo 400 15W-40 oil. I'd like to run 5W-40 full synthetic, but I am too cheap and the Delo seems like a good compromise.
If the manual specs either oil, I wouldn't worry too much about it. Pick a high quality oil in whichever viscosity you prefer.
/ KUbota L3901 400 service #3
Just to confirm... you should be changing the engine oil every 100 hours and the hydraulic fluid at 400 hours. Have you changed the engine oil a few times already???
PS. I use Shell Rotella T 15W-40 Heavy Duty Diesel Oil...
/ KUbota L3901 400 service #4
The Service Intervals in the Operator's Manual has engine oil changes at 50 hours, and then 400 hours and then every 400 hours after that. I see no reason to change the oil more than what the manufacture sets other than to waste oil.
Yes, owners manual says 50 hours, 400 hours and every 400 after that. First 50 hour service I had done by the dealer. I asked because I'm considering doing the 400 hour service myself.
/ KUbota L3901 400 service #6
Regardless of hours, my tractors both get annual oil changes. Going longer than that seems like an invitation for moisture to build up. Just my two cents.
/ KUbota L3901 400 service #7
Kubota factory fill is 10W30.
For northern climates like ours,10W30 conventional is my preference.
Shell Rotella T4 10W30 is the most recent product.
The dealer will also have 10W30 available.
Or go full synthetic 5W40-many great brands out there.
Good Luck!
/ KUbota L3901 400 service #8
Not questioning what your manual say (I am very surprised!!) but here is kubota's website and I see they have backed off from every 100 hours...
http://www.kubota.com/service/MaintenanceSchedule.aspx
I would only try that with full synthetic oil... Actually, that would have meant that I would have only changed the oil 2 in the 12 years I've had mine... No thanks, I'll change it every 100 hours. (maybe the clocks have changed from RPM based to straight time?)
Here is my manual (I change the filter every oil change):
/ KUbota L3901 400 service #9
I grabbed some Delo 15W-40 for my L185DT when I changed the oil at the start of the season. It specified straight 10, 20, or 30 weight based on general outside temps, or 10W-30. I was concerned the slightly thicker oil would cause problems, but it's been running strong for 13 hours so it must be alright.
/ KUbota L3901 400 service #10
I think a couple of years is the maximum regardless of hours (for me). I put about 80 hours per year on my tractors, so I do a service around every 75-100 hours. If you are putting on 400 hours per year, I think that oil change interval is fine. If you put on 80 hours per year like me, I would not run 5 years with the same oil.
/ KUbota L3901 400 service #11
For winter and all year use just run 5W-40 full diesel approved synthetic, change every year or +100 hours or so with filter, then don't worry about it. 400-1000 hrs on the rest of the fluids, depending on use and conditions.
I'm just going by the kubota service schedule for my tractor. So far I'm on track to average 200 hours a year.
/ KUbota L3901 400 service #13
I personally don't think you will have a problem going two years without changing oil. Frequent use is better than non-use for a long period. That said, I would change it annually because I'm a nutcase about maintenance. I see it as cheap insurance. For 30 minutes and 30 bucks, it is worth it for me. I probably over-service my machines, but it gives me peace of mind.
/ KUbota L3901 400 service #14
In change the oil in my tractor annually-around 100 hours of use. I figure it is a small price to pay for peace of mind.
Will
/ KUbota L3901 400 service #15
How about that line in the maintenance schedule to "Replace cooling system Anti-freeze" every year? That seems like overkill.
/ KUbota L3901 400 service #16
Will
My L2550DT gets an oil change every 100 hours. I use Rotella T 15-40 and new filter each time. Some say it is an overkill every 100 hours. I just changed mine a couple days ago at 5503 hours. Yes it is good peace of mind and I have never had an engine issue, ever. Clutches, front differential and that is about it. Regular maintenance is the key to longevity. Shoved a 3/8" stick through the radiator about 20 years ago and bent the tubes back but the little think has yet to spring a leak.
I write on the oil filter the hours and date when the oil change is due. The body looks like it has been through a war but it is mechanically a sound unit. It ain't pretty but it keep up with 75 acres.
Another thing I do is keep the fuel tank full so condensation does not form in the tank.
Gregg
So I called the kubota dealer that I originally bought my L3901 from and spoke to the guy in service to get a price quote for the 400 hour service. To my surprise the guy didn't know how much it would cost, he also didn't know what parts and fluids were required and the costs for everything if I were to do the service myself. He said he'd have to call me back later that day. So anyway I decided to give Union farm equipment a call which is my other local kubota dealer where I've bought many of my implements and spoke to their service guy. I was told worst case scenario if I wanted them to come do the complete 400 hour service at my house that I'd be looking at somewhere in the $500 range. The service guy then said that Kubota has eased up on their maintenance schedule since I bought my tractor and that at 400 hours just a basic service is needed now which just involves engine oil and filter change, air filter and fuel filter change. So for all that to be done by the dealer at my house would cost me $230 and I was quoted around $130 if I bought all the stuff and do it myself. Anyone have any new owners manuals 2015 or newer that say this for the 400 hour service? I'm leaning to just getting the entire service done like my manual says even though the kubota service guy says it's not needed. Thoughts? Oh and I never did hear back from the original kubota dealer, gotta say I'm a little disappointed with that.
/ KUbota L3901 400 service #18
Mine is a L 3301 and it is a 2015. Mine say 400 hrs and that is what I will go by. I check each thing off and keep all purchase records to back them up in case needed later on
/ KUbota L3901 400 service #19
I use Rotella T6 on all my diesels regardless of the manufacturer's listing. It works very well and each engine has run quieter when I switched to it, a small but nice feature.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
(INOP)2006 INTERNATIONAL 4300 SBA 4X2 26' BOX TRK (A60430)
(INOP)2006...
2005 Nissan Frontier Crew Cab Pickup Truck (A59230)
2005 Nissan...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
