Kubota L39 slow/no power to push dirt
   / Kubota L39 slow/no power to push dirt #1
dszlammer
Kubota L39 54003
Kubota L39 slow/no power to push dirt...Not all gears has power
   / Kubota L39 slow/no power to push dirt #2
does it seam like the clutch is slipping?
or does the engine loose power?
   / Kubota L39 slow/no power to push dirt #3
Going to need more information to be of much help. Does it drive normally when it is not under a load?
MarkV
No it doesnt seem like the clutch is slipping. Its operating in gear 1 and 2 and can push dirt in those gears. Motor runs fine no lose of power in both 1 or 2 gear. When it gets warm it doesnt move in gears 2 thru higher.
   / Kubota L39 slow/no power to push dirt #5
will it drive around like normal on flat ground? does it work in all gears?
You are sure the clutch is adjusted correctly? Correct pedal free play?
What year is it? Hours on it?
Only in gear 1 and 2 will it drive ok. then above that it goes into like a neutral. it accelerates but goes nowhere
   / Kubota L39 slow/no power to push dirt #7
Have you changed the trans oil and filter lately?
changed the trans oil and filter todaY. This made the machine run 10% better. Goes up into a few more gears such as 8. Any other suggestions.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2008 JLG 600S TELESCOPIC MANLIFT (A51242)
2008 JLG 600S...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
