Kubota L39 Error Code 61 -66
   / Kubota L39 Error Code 61 -66 #11
The wireing harness is most likely what is wrong. Check for a loose wire. Just had mine knocked off tonight by a small 2" tree. Tractor runs throught the gears but is still showing a Error 66. I will check the fuses next as suggested above. Good luck..
I would just like to say "Thank You" for this thread and everyone's advice. My L3130 decided it was time to take a dump on the side of the hill. No forward, no reverse, looking at the dash I had codes 61 through 66......WTFO? I know it has good fluid, levels are where they're supposed to be......this happens to be the the only toy I don't have a service manual for, so I ordered a new set. Then went searching for a solution on the net. I came across this and checked fuses.....all good......then I checked the wiring harness to the trans. Hoo-Yah! there it was, plugged it back in and off she went! Again, many thanks, I just thought some folks would like to know they fixed my tractor.
I became a member just so I could post this.
   / Kubota L39 Error Code 61 -66 #12
:welcome:aboard sardaddy, this is a very old thread. I think it was started in 2012.
   / Kubota L39 Error Code 61 -66 #13
Thanks and who cares how old it is, it's still good advice. I just happened across it doing a search. Currently working a new retirement home (#3) Hope to be moved in before winter.
QUALITY TRAILER 3 CAR HAULER GOOSENECK TRL (A52708)
QUALITY TRAILER 3...
1997 Ford E-250 Cargo Van (A56858)
1997 Ford E-250...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
1994 Blue Bird Command Center Bus (A55973)
1994 Blue Bird...
