Backhoe Kubota L39 Backhoe disconnect
   / Kubota L39 Backhoe disconnect #11
Just an update on this post. I have an L39 with the BT1000 backhoe and the instructions are in front of your feet on the backhoe controls. It also makes it easier to install and uninstall the pins by using a dremel/air tool with either the round sanding fins or the wire brush attachment to clean out the holes where the pins are inserted. Then I put a little antisieze on the pin. The first couple times I removed the backhoe I had to use a pry bar and hammer to get the pins out. After dremeling the holes where the pins go it made it much easier. Some of the paint and rust makes little high spots that don't allow the pins to release. The other thing to do if the pins won't release is gently raise and lower the back of the tractor off the ground with the backhoe and watch the pins. You will see them slightly move when the pressure is released. My left pin comes right out when I lift the tractor off the ground, but the right pin needs the tractor just touching the ground for it to release easily.
   / Kubota L39 Backhoe disconnect #12
watch the pins to see when the pressure is off, this applies to FEL, 3point, etc..
OK , I am back and can now report that I have removed and re-attached multiple times now my BH. Yes, I was a bit nervous the first time particularly when the pins would not budge. With some work they come out and since the addition of a little grease applied to the pins the following removals have been a breeze. Everyone was right about the level ground; of great importance as I did learn that lesson brielfly one sunny day there in Wyoming. But short of that it all went well and it now is about a 5-8 minute exercise for me. My thanks to all those that offered encouragement and insight!
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
White Metal Roof Panels (A55758)
White Metal Roof...
TANK MANIFOLD (A58214)
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
