Kubota L3830 Headlight
   / Kubota L3830 Headlight #1
sbeckwith
John Deere 4720, Kubota L3830, John Deere 2355 MFWD, John Deere 4430, Case 1030, John Deere B, John Deere 730D, Hustler SD60
While using the 3830 to bring in firewood, I had a sapling take out the head lamp and bend some of the area up a bit. I believe I'll be able to straighten the damaged area to near new looking, but I will need to replace the headlamp assembly. Is OEM the only option or the best option? Where would folks recommend I pick one up at?
Thanks everyone,
Steve
   / Kubota L3830 Headlight #2
I have had good luck with"Messicks",online catalog ,good service.
   / Kubota L3830 Headlight #4
NY Bird has a good one with Messicks. I've ordered a number of things from them in the past and have always had good luck. With the way that Kubota is setup, I wasn't able to find the headlight online anywhere except Tractor Help.
Replacement parts for a Kubota L3830DT/GST/HST Tractor
Have a friend at the local dealer that said $129.86 for the light and Tractor Help has it for $123.
Anytime I go through the woods I always wonder if it's going to get pricey. It's the same comment that I make when I see someone run over a parking berm with a car..."Just keep going until it sounds expensive" haha
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2014 Doosan DA30 (A53472)
2014 Doosan DA30...
