Kubota L3830 Headlight
   / Kubota L3830 Headlight #1
sbeckwith
John Deere 4720, Kubota L3830, John Deere 2355 MFWD, John Deere 4430, Case 1030, John Deere B, John Deere 730D, Hustler SD60
While using the 3830 to bring in firewood, I had a sapling take out the head lamp and bend some of the area up a bit. I believe I'll be able to straighten the damaged area to near new looking, but I will need to replace the headlamp assembly. Is OEM the only option or the best option? Where would folks recommend I pick one up at?
Thanks everyone,
Steve
   / Kubota L3830 Headlight #2
I have had good luck with"Messicks",online catalog ,good service.
   / Kubota L3830 Headlight #4
NY Bird has a good one with Messicks. I've ordered a number of things from them in the past and have always had good luck. With the way that Kubota is setup, I wasn't able to find the headlight online anywhere except Tractor Help.
Replacement parts for a Kubota L3830DT/GST/HST Tractor
Have a friend at the local dealer that said $129.86 for the light and Tractor Help has it for $123.
Anytime I go through the woods I always wonder if it's going to get pricey. It's the same comment that I make when I see someone run over a parking berm with a car..."Just keep going until it sounds expensive" haha
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
