Kubota l3800 bro-Tek 2” spacer install.
   / Kubota l3800 bro-Tek 2” spacer install. #1
mi462478547
Hudson
Kubota
I have a Kubota L3800 with R4 tires that are filled. I need to remove the tire and wheel to install the spacers. Is this a DIY task? Can I do this myself? Looking for suggestions on handling the tire and wheel. I will jack and block the tractor itself. Concerned about getting wheel off and back on the tractor.
Thanks
   / Kubota l3800 bro-Tek 2” spacer install. #2
You can jack the tractor up just enough to take pressure off the lug bolts and roll the tire out of the way. If you had an engine hoist to lift up on the tire you could increase the safety of the plan.
Thanks for the reply. I was also thinking of a wheel dolly.
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
17345 (A56859)
17345 (A56859)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
40 Gun Fireproof Safe (New/Unused) (A59225)
40 Gun Fireproof...
