Kubota l3800 bro-Tek 2” spacer install.
   / Kubota l3800 bro-Tek 2” spacer install. #1
mi462478547
Hudson
Kubota
I have a Kubota L3800 with R4 tires that are filled. I need to remove the tire and wheel to install the spacers. Is this a DIY task? Can I do this myself? Looking for suggestions on handling the tire and wheel. I will jack and block the tractor itself. Concerned about getting wheel off and back on the tractor.
   / Kubota l3800 bro-Tek 2” spacer install. #2
You can jack the tractor up just enough to take pressure off the lug bolts and roll the tire out of the way. If you had an engine hoist to lift up on the tire you could increase the safety of the plan.
Thanks for the reply. I was also thinking of a wheel dolly.
2007 Pantropic Power ECP34 T/A Towable Generator (A46683)
2007 Pantropic...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
Pull-Type Lime Drill (A49251)
Pull-Type Lime...
2007 International 7500 sba Flatbed 6x6 Truck (A47371)
2007 International...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A47371)
2011 Autocar ACX64...
2012 Ford F-350 Omaha Service Truck (A48081)
2012 Ford F-350...
