number two
- Joined
- Apr 2, 2007
- Messages
- 1,386
- Location
- Northern Lower Michigan
- Tractor
- Kubota B3030HSDC Kubota L2501HST
HST model?
Seems like you have one.
Assume you mean engine will not crank when turning the switch?
Clutch pedal must be depressed to crank the engine.
Glow plug lamp will light up when switch is turned to run,then go out a few seconds later when ready to start.
Remember servicing a deceased friends L3010-I could start on the floor just by depressing the clutch pedal.
Of course he had no HST switch issues and I could move the tractor without being in the seat.
Lots of L's have inoperative glow plug systems.
Just ask No Trespassing!
And don't forget to keep the HST pedal well greased!
Hope this helps.
Good Luck!
Hope this helps.
Good Luck!
