Kubota L3710 overheating
   / Kubota L3710 overheating #1
haggus
Brazoria, Texas
Kubota
Approximately 1996 model runs all day long at low <2000 rpm but when I idle up to engage the PTO it immediately overheats. Thermostat / radiator / other. I am new at this and any help is welcomed.
   / Kubota L3710 overheating #2
How have you determined t's overheating? If it's the gauge, have you checked it with a thermometer?
Make sure the thermostat is opeing, the radiator air side isn't clogged with chaff, the water pump drive belt is tight and not slipping, the air cleaner is not clogged, the rad cap is the right pressure rating and is working, the coolant side of the radiator isn't clogged. Look for bubbles in the coolant indicating a head gasket leak.
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2015 ISUZU NPR 16FT BOX TRUCK (A51219)
2015 ISUZU NPR...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
