Kubota L3700 Rear Hydraulic Install
   / Kubota L3700 Rear Hydraulic Install #1
finchm
floyd, va
kobota l3700su
I added 4 ports to the back of my L3700. I used a Prince stacked valve. The first two sections have float, the third is a normal spring return valve, and the forth is a detent valve. I ran 3/8" hose for all the plumbing.
The stacked valve is actually pretty heavy and I made a mounting plate of 1/4 steel to hold it together. I mounted it so that I still have full access to my cup holder.
The Prince valve uses O-Ring BOSS fittings. I used fittings that converted the O-Ring Boss fittings to JIC male. I used #8 JIC double ended female hoses for all plumbing to keep things consistent with the rest of the tractor.
I painted the valve after assembling it and before plumbing it per many suggestions. http://www.tractorbynet.com/forums/hydraulics/274388-should-i-paint-my-valve.html
The Prince stacked valve has very tight spacing of the work ports. It is NOT possible to install 90 degree fittings next to each other after the valve is assembled. If you wish to use 90 degree fittings, install them before assembling the valve. An alternative is to use straight O-ring BOSS fittings and 90 degree JIC fittings on top of them (parts - 6400 & 6500 )
Picture 1: Hooking into existing in, out, and tank lines.
Picture 2: Side view showing in,out, and tank lines going into the valve
Picture 3: Rear view. Showing 2 of the 4 ports plumbed up. The mounting plate for the quick disconnects is a piece of 1/4" plate with bulkhead fittings. The plate is attached to the ROPS using three hose clamps.
Picture 4: Rear view, different angle
Picture 5 & 6: Two front views of the valve
Picture 7: Rear view, zoomed out
   / Kubota L3700 Rear Hydraulic Install #2
Nice install. Looks good.
Did you set the relief on the new valve?
   / Kubota L3700 Rear Hydraulic Install #3
Very nice!
I didn't set the relief pressure on the new valve. The instructions said it was factory set at 2000psi. My primary tractor relief is set at 2500psi.
Is this acceptable?
   / Kubota L3700 Rear Hydraulic Install #5
You can set the new valve to your tractor psi.
If you leave it at 2000 psi, you lose potential force and lifting power.
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2025 Wolverine BC-13-72W 66in Brush Cutter Skid Steer Attachment (A52378)
2025 Wolverine...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
