Kubota L3560LE work light wiring
   / Kubota L3560LE work light wiring #1
coopers1
Fly Creek, NY
2021 Kubota L3560LE
I've tried looking for my answer in the search bar but haven't found it. I'm adding LED lights to my L3560LE and I'm curious if anyone knows which of these pictured connectors is the correct one for the work lights. My lights mount fine on the front, need to find a bracket for the rear ones. At any rate, thanks in advance for answers.
   / Kubota L3560LE work light wiring #2
Image 0232 is one of the light switches I believe. There are 2 switches, 1 for front & 1 for back. Both are located in the pillar next to the loader joystick. Should be wired the same.
The skinny 2 pin plugs up in the roof are the connectors for the lights.
0235 is the plug for the radio.
Thank you!
   / Kubota L3560LE work light wiring #4
Might be useful links to some of my previous wiring projects or posts.
   / Kubota L3560LE work light wiring #5
Your owners manual should have a wiring diagram with color codes and wire sizes
A multimeter helps too
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
